Author Topic: Are root privs required to install?  (Read 4203 times)
NightStorm
« on: May 18, 2011, 11:19:37 am »
I get this :
(OpenSUSE 11.4 x64)
Ryan
  • Hero Points: 77
Re: Are root privs required to install?
« Reply #1 on: May 18, 2011, 01:47:44 pm »
Root privileges are required if you are installing into a directory that requires root privileges to write to that directory...ie. /usr/local .
Also, just as an FYI, I see that you are on a 64 bit OS...which is fine...but the current version of the SlickEdit plugin will not run in a 64 bit JVM.  It requires a 32 bit JVM.  The next major release of the plugin (Summer 2011) will support a 64 bit JVM.
- Ryan
NightStorm
« Reply #2 on: May 18, 2011, 02:05:51 pm »
OK, thanks.  I thought I'd take a look at it, I'll revisit this when the 64 bit support is out (we are all running with 64 bit VMs here).
