Author Topic: How do I get Slickedit to find my #include files?  (Read 3037 times)
timur
  • Hero Points: 3
« on: June 02, 2011, 10:06:41 pm »
I'm using Slickedit to work on the Linux kernel, which keeps all header files in the include/ directory.  So if I want to include a header file, I need to make sure I don't specify the "include/" part.  That is:
#include <linux/string.h>
Includes the file include/linux/string.h
It seems to me that Slickedit understands the #include directive and wants to help me find header files, but that doesn't seem to work.  How do I tell it that all header files are under include/ ?
Searching the help files got me nowhere.
jimlangrunner
  • Hero Points: 31
Re: How do I get Slickedit to find my #include files?
« Reply #1 on: June 03, 2011, 01:37:44 pm »
I'm guessing here, but it rings a bell.
Under Project Properties, Directories tab.  In the includes, do you have /include/ ?  From there, it should find the includes you're working with.
I assume from your post that
#include </include/linux/string.h> is not permitted. What about
#include <./linux/string.h>?
ScottW, VP of Dev
  • Hero Points: 64
« Reply #2 on: June 03, 2011, 01:42:24 pm »
Sorry if this is an obtuse question, but what is the specific behavior you are after? Is this issue about completing your #include statement as you type or is it about tagging and navigation?
timur
  • Hero Points: 3
« Reply #3 on: June 05, 2011, 01:31:49 am »
I am under the impression that when I type in
#include <lin
That Slickedit can fill in the "ux" part for me and change that into
#include <linux/
Maybe I'm imagining things, but I could have sworn I was able to do this once.  It's a sort of "tab completion" for #include statements.
  • Hero Points: 463
« Reply #4 on: June 06, 2011, 06:40:31 pm »
Document > C/C++ Options > Auto-Complete ...
Check your setting for "List include files after typing #include"
Jim is correct that the include paths it uses are based on the include directories configured for the current project, as well as the C++ compiler include directories.
