Author Topic: Export/Import SE options from 16.0.0.6 to 16.0.1  (Read 2626 times)
ehab
  • Hero Points: 15
  • coding with SE is like playing music
« on: July 25, 2011, 10:30:47 am »
hi
I had 16.0.0.6 Windows, exported my settings, uninstalled it then installed 16.0.1, then imported my settings.
expected: my settings are imported.
outcome: SE starts importing and then hangs, must be killed to exit. If i waited for a long time then it will says "Failed .. "  I think its File category or other.
I have attached my setting zip file for anyone to try.
Hope the export and import options issues get resolved because it is important.
regards
ehab
« Last Edit: July 25, 2011, 01:31:19 pm by ehab »
Sandra
  • Hero Points: 36
Re: Export/Import SE options from 16.0.0.6 to 16.0.1
« Reply #1 on: July 25, 2011, 01:25:02 pm »
I have found the problem.  It will likely take a hot fix to correct, but until then, I've got a workaround for you so you can get working again.  After you pick the zip file to import, an Options dialog will pop up and allow you to select which options to import.  On this dialog, go to File Options > Open and uncheck Show Hidden Files.  Then go ahead and import the rest of the options.
Let me know if you have any other problems.
ehab
  • Hero Points: 15
« Reply #2 on: July 25, 2011, 01:30:31 pm »
correct catch.
hp++ for you and thanks.
