Author Topic: File Tabs multi-row?  (Read 3354 times)
Shelku
« on: August 17, 2011, 03:44:34 am »
Is there a way to make the "File Tabs" Tool Window multi-row? Sometimes I find it fills up pretty fast and a second row would be handy. I tried dragging the editor window up to make room, but that didn't do anything.
Somewhat related, I have my References, Search Results, Build and Output tool windows unpinned and on the bottom, but it doesn't seem to let me move the file tabs to the same row as those. I could free up some more screen real estate if I had more flexibility with moving the file tabs around.
Phil Barila
  • Hero Points: 61
Re: File Tabs multi-row?
« Reply #1 on: August 17, 2011, 03:23:16 pm »
I gave up begging for a multi-row File Tab toolbar at the second or third release with the Filetab toolbar, when it still didn't support multi-row.  The constant for it exists, but setting it doesn't result in a multi-row bar.  Maybe you'll be more successful than I.
