Author Topic: Comment formatting not working correctly  (Read 1449 times)
jorick
  • Hero Points: 16
« on: September 02, 2011, 01:34:03 pm »
Comment formatting seems to be broken in certain cases.
Given the following comment blocks:
* Block 1
* Block 2
Comment formatting is disabled for block 2.  It doesn't matter how much whitespace exists between the blocks (even none at all).
However, if block 2 has /** (or any number of * greater than 2) starting the block, comment formatting works.  Adding any other character other than * doesn't work (such as /*x).
SlickEdit 2011 (v16.0.2.0 64-bit)
License file: C:\ProgramData\slickedit\16\slickedit.lic
Build Date: August 11, 2011
Emulation: CodeWright
OS: Windows 7 x64
Memory: 25% Load, 4124MB/16340MB Physical, 4371MB/32680MB Page File, 210MB/8388607MB Virtual
Screen Size: 1680 x 1050, 1680 x 1050
Project Type: No project open
Language: .c (C/C++)
Installation Directory: C:\Program Files\SlickEditV16.0.2 x64\ (non-removable drive,NTFS,407811MB free)
Configuration Directory: C:\Users\...\Documents\My SlickEdit Config\16.0.2\ (non-removable drive,NTFS,407811MB free)
Hotfixes:
C:\Users\...\Documents\My SlickEdit Config\16.0.2\hotfixes\hotfix_se1602_2_cumulative.zip (Revision: 2)
