Author Topic: Searching for substrings  (Read 2844 times)
outsider
« on: September 10, 2011, 07:07:37 pm »
Hi guys,
I can't find it if it exists, but is there a SlickEdit function for searching for a substring within a string (preferably one with regex)? All the functions I've found so far regarding search pertain to the whole of the current or named buffers, either explicitly or implicitly.
thanks
LBCEi
  • Hero Points: 20
Re: Searching for substrings
« Reply #1 on: September 10, 2011, 07:18:36 pm »
You can search within a selection.  So, unless I misunderstand your question, just select the string within which you wish to search, Ctrl-F, enter your desired search regex and you get what you want.
Since you use the word "function", perhaps you are looking for a way to do this in a Slick-C macro?  In which case you should post this question in the Slick-C macro programming forum.
Good Luck
outsider
« Reply #2 on: September 10, 2011, 09:19:16 pm »
Yes LBCEi, I'm looking for a Slick-C function which will accept the string to search as an argument. Don't know how to move the post so maybe I'll repost there.
Thanks for responding.
  • Hero Points: 325
« Reply #3 on: September 10, 2011, 09:25:20 pm »
Try the pos function.
outsider
« Reply #4 on: September 12, 2011, 02:56:40 pm »
Perfect! Thanks once again Graeme.
