Author Topic: Format c# Arguments  (Read 4911 times)
AhsGrad1973
Format c# Arguments
« on: October 06, 2011, 11:07:47 AM »
I use this macro to add the number of arguments to a String.Format, Console.WriteLine, etc in c#:
_command brief_AddFormatArguments() name_info(','VSARG2_REQUIRES_EDITORCTL)
        // Ctrl+S
    typeless orig_position;
    int iI;
    int iPos;
    int iLen;
    int iParms = 0;
    boolean fTrue       = true;
    boolean fSingleLine = false;
    _str strMethod;
    _str strParms;
    _str strLine;
    _str strText;
    _save_pos2(orig_position);
    get_line(strMethod);
    iPos = lastpos(");", strMethod);
    if (iPos > 0)
        fSingleLine = true;
        strLine = strMethod;
    iPos = lastpos("(", strMethod);
    if (iPos > 0)
        strMethod = substr(strMethod, 1, iPos);
    else
        iPos = pos("\"", strMethod);
        if (iPos > 0)
            strMethod = substr(strMethod, 1, (iPos - 1));
    if (fSingleLine == false)
        while (fTrue)
            down();
            get_line(strText);
            if (last_char(strText) == ";")
                iParms++;
                break;
            else
                iParms++;
    else
        iLen = length(strLine);
        iPos = pos("\",", strLine);
        if (iPos > 0)
            strParms = substr(strLine, iPos, (iLen - iPos));
            STRARRAY strParams = split2array(strParms, ",");
            iParms = (strParams._length() - 1);
        else
            _restore_pos2(orig_position);
            return (0);
    if (iParms > 0)
        strMethod = strMethod:+"\"";
        _str strRet = _message_box("Yes = Use a space\r\nCancel = Use a comma\r\nNo = No separation.",
                                   "What do you want to use as a separator?",
                                   MB_YESNOCANCEL | MB_ICONQUESTION | MB_DEFBUTTON1);
        for (iI = 0; iI < iParms; iI++)
            if (strRet == IDYES)
                if (iI < (iParms - 1))
                    strText = "{":+iI:+"} ";
                else
                    strText = "{":+iI:+"}";
            else if (strRet == IDNO)
            else // IDCANCEL
                strText = "{":+iI:+"},";
            strMethod = strMethod:+strText;
        if (fSingleLine == true)
            strMethod = strMethod :+ strParms :+ ";";
        else
            strMethod = strMethod:+"\",";
        replace_line(strMethod);
    return (0);
lclevesy
  • Guest
Re: Format c# Arguments
« Reply #1 on: October 06, 2011, 01:57:50 PM »
@AhsGrad1973 Thank you for your submission. It is in the running for the iPad!
The winner will be announced via our Facebook page https://www.facebook.com/slickedit, Twitter page http://www.twitter.com/slickedit, and on this forum under the main SlickEdit October Macros Challenge Rules & How to Enter post http://community.slickedit.com/index.php/topic,7327.0.html on November 7, 2011.
lclevesy
  • Guest
« Reply #2 on: November 01, 2011, 03:15:25 PM »
We'll be announcing the winner of the iPad 2 on November 7th. Until then, your submission has earned a SlickEdit t-shirt! Email your size and address to marketing@slickedit.com to receive one.
