I uses SlickEdit 2011 (v16.0.3.0 64-bit), and have some problems with Perl.
If I have some code like:
given($input)
when("a")
# a statements
# Other statements
when("q")
return;
default
print "Select from menu:\n";
my $i = 0;
my @keys = keys %menu;
foreach (@keys)
printf("[%u] %s\n", $i, $keys[$i]);
$i++;
print "q for exit\n";
} while ($input = <STDIN>);
The problem is when running from inside SlickEdit, the capture output prevent from setting the input during running, and seeing any output before the program is finished running.
If I disable capture output, it starts the application in a cmd, and it works as expected.
Though the problem is that this cmd window is closed by itself when there is a syntax error.
I can of cause create two execute commands, but is their not a better way?
How do you others write Perl scripts with uses STDIN in SlickEdit?
Thanks ahead
