Author Topic: CRLF gets added when I perform a paste of a copied word  (Read 2636 times)
Jackie3
« on: April 24, 2012, 11:14:00 am »
I'm using Visual SlickEdit Version 8.0 and it has always been pretty stable. Recently, I have a problem when I copy some text. The paste operation adds a CRLF to the word that I want to paste. I am using Brief emulation. For example:
It's raining cats and today, If I paste in the word dog. I should get:
It's raining cats and dogs today.
But instead I get:
CRLF today.
I compared all configuration settings with another computer that works OK and all the settings are the same. I really need to prevent the CRLF from getting pasted.
Jack
Jackie3
Re: CRLF gets added when I perform a paste of a copied word
« Reply #1 on: April 24, 2012, 11:27:31 am »
Additional info: When I checked the Clipboard, the CRLF was present after the copied word.
Phil Barila
  • Hero Points: 61
« Reply #2 on: April 24, 2012, 05:03:05 pm »
If the CR/LF is present in the Clipboard, it should get pasted.  Ensure your selection doesn't include the EOL, and you should be fine.
Jackie3
« Reply #3 on: April 25, 2012, 12:33:22 am »
Hi Phil,
I did not copy the EOL. For example, if I type out:
123
and then hightlight the 2 and do a copy and paste, I get:
12
23
On my other machine, which works correctly, the result is:
1223. So for some reason a CRLF is getting added to the copy buffer when
the text is copied.
Jack
Phil Barila
  • Hero Points: 61
« Reply #4 on: April 25, 2012, 01:18:24 am »
Ouch.
Does it do the same thing if you run it with a clean config?
Does copy/paste in Notepad suffer the same thing?
Sorry, I don't have any other suggestions of the top of my head.
