Author Topic: Old macros won't load with SE V17?  (Read 5875 times)
namklak
« on: August 31, 2012, 08:00:58 PM »
Hi,
I wrote some macros back in 2002 and tweaked a couple of them in 2009.  I started at a new company and installed SlickEdit V17, and SE complains "Unable to load module <file name>. Incorrect version."  How do I fix these macro modules?
-Bob
nhed
Re: Old macros won't load with SE V17?
« Reply #1 on: August 31, 2012, 09:54:02 PM »
Bob,
Your post is so vague, I am surprised I am even answering it
I am guessing you are trying to load a .ex, not a .e file
please provide:
- File name, not just "<file name>" (to ensure you are not trying to load compile macros)
- A bit of the macro code - even if its empty (yes, try to load a no-op macro)
If this is the case, make sure you remove the .ex file, if this is not the case, at l;east post your macros and see if anyone has more advice
--Nevo
  • Hero Points: 342
« Reply #2 on: September 01, 2012, 12:50:51 AM »
