Author Topic: Why should "beautify while typing" denigrate java?  (Read 2979 times)
RaffoPazzo
« on: September 11, 2012, 09:26:37 AM »
That's the question...What's that deep difference with C/C++/ObjectiveC and Java such that this features isn't available for Java too?
  • Hero Points: 151
Re: Why should "beautify while typing" denigrate java?
« Reply #1 on: September 11, 2012, 01:38:43 PM »
It's not due as much to deep differences in syntax, as to the available time.  SE2012 was heavily front-loaded with a lot of work for the generic pieces of the beautifier engine and related boilerplate, so C++ and Obj-C was all we could fit into the schedule.
Now that the basics are already in, adding Java into SE2013 has been mostly a matter of just addressing the differences between our "common to most brace languages" module, and additional syntax in Java.  So it's going pretty quickly.
RaffoPazzo
« Reply #2 on: September 11, 2012, 02:05:11 PM »
Thanks for your reply.
I really hope SE's java support will soon be as full as the C/C++ is and that it will finally far ahead than the Eclipse/NetBeans counterparts...
