Author Topic: Configuration for all users  (Read 2702 times)
meitalr
« on: January 16, 2007, 04:34:05 pm »
Hi,
I would like to setup the SlickEdit configuration for all the developers in my team.
By configuration I mean:
- The added project tools (i.e. build-dbg).
- The source control definitions (I added BK support).
- Tabs definition, bracets definition etc.
From what I've learned so far, I understand that I need to copy the following files to other users:
a. <>.vpw, <>.vpj files. (which is a little problematic since it holds the files definition too)
b. .slickedit/11.0.2/usrprjtemplates.vpt -- for the template project I defined
c. .slickedit/11.0.2/user.vlx -- for the lexer I defined
d. .slickedit/11.0.2/uservc.slk -- for the BK definitions
My Q's are:
1. Have I missed some file that needs to be copied?
2. Can I just copy all .slickedit/11.0.2/ directory? or will this create a problem?
3. Is there a better way for setting up everyones settings and configuration?
Meital
