Author Topic: Populate a view from proc_search?  (Read 13310 times)
JimL
« on: January 02, 2013, 03:38:34 PM »
Hi,
Wasn't sure if this should go here or in the Programming community but is there a way to populate an eclipse view from the proc_search routine within a language processor?   In my case I'm trying to add to the Problems View based on results from proc_search, but I'm unsure how to get to a plugin from a .e
Thanks
Ryan
  • Hero Points: 77
Re: Populate a view from proc_search?
« Reply #1 on: January 02, 2013, 04:01:58 PM »
So you have a proc_search written for a language and you want to be able to populate the Problems view in Eclipse based on something that happens in the proc_search?  Sort of like a real-time errors utility?
Unfortunately we don't have the facility for that yet.  I just double-checked our Bugzilla, because I was pretty sure I have heard a similar request before, and we do indeed have an existing feature request to provide an API in SlickC for populating the Problems view.  That is what you would need, and I went ahead and bumped that thread with your information.  Hopefully we can put something together for this in our next major release.
- Ryan
JimL
« Reply #2 on: January 03, 2013, 06:54:13 PM »
Thanks Ryan.    And, yes, you accurately described what I am looking for.
