Author Topic: 'codehelp' for structures with attributes.  (Read 3953 times)
johneegeek
« on: January 16, 2007, 05:29:33 pm »
I've been a long time slickedit user, and one thing always has annoyed me.
Codehelp works great with structures UNLESS you do something like this:
#if defined(__GNUC__)
    #define PACKED_TYPE __attribute__((packed))
#else
    #define PACKED_TYPE
#endif
typedef struct {
    int whatever1;
    int whatever2;
} foo_t PACKED_TYPE;
Now codehelp does nothing with this structure.
(i.e. there is no struct completion on a ".")
Is there a way around this? :-\
  • Hero Points: 289
Re: 'codehelp' for structures with attributes.
« Reply #1 on: January 16, 2007, 07:55:59 pm »
johneegeek
« Reply #2 on: January 16, 2007, 08:08:41 pm »
Excellent!  ;D thanks.
Sorry for asking the same question, I tried searching for the problem but didn't get right combination of search terms I guess.
Works great now, wish I would have look into this sooner.  ::)
