Author Topic: Can I point as structure defined a name(in C) in slickedit?  (Read 4708 times)
kutay
« on: February 11, 2013, 04:22:37 PM »
Hello,
I'm programming some microcontrollers in C.
if possible, I want to point in slickedit as structure a defined name (in C programming)
for exemple:
MyTypedef is a structure and  it points an address
typedef struct{
    unsigned char lo;
    unsigned char hi;
}MyTypedef;
#define MyReg (((MyTypedef *)(0x12345678)))
Normally, I can access following
Myreg->lo=10;
But I want to see structure members after typing "Myreg->".
Slickedit shows for pointer variables but I want to see defined names , is this possible?
Thx in advance.
  • Hero Points: 292
Re: Can I point as structure defined a name(in C) in slickedit?
« Reply #1 on: February 11, 2013, 08:44:34 PM »
Try adding the MyReg macro to the 'C/C++ Preprocessing' settings. HS2
kutay
« Reply #2 on: February 12, 2013, 10:50:09 AM »
hello hs2,
 thx for your reply, Please you can say or show , How can I add in slickedit C/C++ preprocessing?
I tried adding in tools-> options-> app languages-> C/C++-> C/C++ preprocessing but  It didnt work as structure
Thx in advance
  • Hero Points: 292
« Reply #3 on: February 12, 2013, 01:04:23 PM »
In the C/C++ PreProc. dialog just enter/paste the macro code in the edit window:
#define MyReg ((MyTypedef *)(0x12345678)) and 'Apply' and say 'Yes' to retag your workspace.
Note that also macro args are supported ie.
#define RegPtr(p)  ((MyTypedef *)(p))HS2
kutay
« Reply #4 on: February 16, 2013, 11:08:00 AM »
thanks alot
