Author Topic: Beyond Compare  (Read 4149 times)
wallybarnum
Beyond Compare
« on: February 20, 2013, 06:13:28 PM »
Is there any way to use Beyond Compare 3 as the default diff and merge tool with SlickEdit?  I would like it for svn source control integration diffs and merges, i.e. when right clicking the a file and selecting "Version Control -> Diff... or Compare Directory...." it would pass the arguments to Beyond Compare instead of DiffZilla.
I see on the forums some other posts about using a custom macro to launch BC3 but no source for the macros provided and I'm not experienced at creating SE macros.
There does not seem to be an easy way to point SE to use an external diff and merge tool, but if anyone can point me to some good user created macros I'd appreciate it.
thanks - w
