Author Topic: Add a new ClearCase command  (Read 2250 times)
RaffoPazzo
« on: March 26, 2013, 04:03:42 pm »
Hi guys, I'm wondering if it is possible to add a new ClearCase command in the Version Control menu.
In Tool / Options / Version Control / ClearCase / Commands I can find the list of existing commands and even change some if I want. But how do I add a new one? For example, to create an UCM activity ...
Thank you in advance.
  • Hero Points: 291
Re: Add a new ClearCase command
« Reply #1 on: March 26, 2013, 08:52:49 pm »
AFAIK there is no way to user-extend SE version control and I think it's more complicated than it seems at the first place.
(So I've added a simple macro command for 'version tree' and just know how/when to use it..)
