Author Topic: Incorrect help on perforce options setup  (Read 3298 times)
sndom
« on: April 25, 2013, 12:11:14 pm »
In the options for the command line Perforce setup, the help for the "Perforce executable" setting says "Specifies the path to the Subversion executable that you wish to use"
  • Hero Points: 141
Re: Incorrect help on perforce options setup
« Reply #1 on: April 25, 2013, 12:16:43 pm »
Fixed for next beta.  Thanks!
