Author Topic: tab groups not remembered when SE closes/reopens  (Read 5860 times)
davehohl
  • Hero Points: 27
Re: tab groups not remembered when SE closes/reopens
« Reply #15 on: April 26, 2013, 09:44:16 pm »
Well, my config dir has always been on that U: drive, and I have never had a problem with previous versions, so there is something about V18 that is different. There are no other instances of vs.exe running.
skywise
  • Hero Points: 10
« Reply #16 on: April 29, 2013, 03:04:42 pm »
I would bet this is related to your other post "Unable to save...Path not found" issue -
http://community.slickedit.com/index.php/topic,8952.0.html
  • Hero Points: 461
« Reply #17 on: April 29, 2013, 03:53:26 pm »
The Windows network save issues will be fixed in the next beta.
davehohl
  • Hero Points: 27
« Reply #18 on: May 01, 2013, 10:04:16 pm »
This problem appears to be fixed in Beta 2.
