Author Topic: Has Windows XP support been dropped?  (Read 2024 times)
Russ
  • Hero Points: 3
« on: April 26, 2013, 12:13:20 am »
I get an error about GetFinalPathNameByHandleA which is only available in Visa and above?
at5dapa1
  • Hero Points: 18
Re: Has Windows XP support been dropped?
« Reply #1 on: April 26, 2013, 11:15:54 am »
Seems so. I got the same error, thought first that the installer failed or that I started the 64bit...
Well, I'll have to wait to get the Win7 and till then I'll new SE try home. :-)
  • Hero Points: 313
« Reply #2 on: April 29, 2013, 12:02:55 pm »
Really?  We're still using Windows XP at work...
« Reply #3 on: April 29, 2013, 12:56:39 pm »
Windows XP is still supported.  This will be fixed in next beta drop.
