Author Topic: newly opened files do not appear in new tab  (Read 3154 times)
davehohl
  • Hero Points: 27
« on: April 26, 2013, 05:50:33 pm »
I tried to replicate the actions shown in the video about how to use the new MDI features. If I start with an empty editing window and open a file, it appears in the window along with a tab containing its name. If I now open a second file, the original goes away and is replaced with the new file/tab. I do not get the behavior shown in the video, where each time a file is opened it gets a new tab.
I looked around in the Options menu to see if I needed to change some setting, but could not find anything that looked pertinent. What could I be doing wrong?
SlickEdit 2013 (v18.0.0.5 32-bit)
Serial number: FE25543_BETA
License type: Beta License
License expiration: 2013-07-24 12:01:00
License file: C:\ProgramData\slickedit\18\slickedit.lic
Build Date: April 23, 2013
Emulation: CUA
OS: Windows 7
Memory: 69% Load, 2301MB/3318MB Physical, 3003MB/6635MB Page File, 310MB/2047MB Virtual
Screen Size: 1920 x 1200
Project Type: Cpp
Language: .h (C/C++)
Installation Directory: C:\Program Files\SlickEditV18.0.0 Beta1\ (non-removable drive,NTFS,221661MB free)
Configuration Directory: U:\MyDocs\My SlickEdit Config\18.0.0\ (remote,NTFS,31554MB free)
Spill File: C:\Users\david.hohl\AppData\Local\Temp\$slk.5 (non-removable drive,NTFS,221661MB free)
Rodney
  • Hero Points: 49
Re: newly opened files do not appear in new tab
« Reply #1 on: April 26, 2013, 05:59:35 pm »
You need to turn ON One-file-per-window (Tools>Options>Editor Windows, Files per window).
I will factor this into the other problem you posted about.
++rodney
Rodney
  • Hero Points: 49
« Reply #2 on: April 26, 2013, 06:00:21 pm »
Also, if you turn on One-file-per-window, then you will probably want to hide the File Tabs tool window, since it would be redundant and confusing.
davehohl
  • Hero Points: 27
« Reply #3 on: April 26, 2013, 06:10:08 pm »
Thanks, that did the trick!
