Author Topic: Window tab - how to remove?  (Read 2441 times)
dunkers
  • Hero Points: 28
« on: May 01, 2013, 02:02:17 am »
How does one remove the window tab (not the strip of file tabs)? The one I mean is the one arrowed in the picture.
I've checked the toolbars, tool windows and any windows related dialog in options, but can't find where these are configured.
dunkers
  • Hero Points: 28
Re: Window tab - how to remove?
« Reply #1 on: May 01, 2013, 02:41:49 am »
Mmmm. I guess these are really a new style of the old MDI window title bar and, hence, part of the window? I was thinking it would be cool if I could reclaim the space they take up, you see...
Ryan
  • Hero Points: 77
« Reply #2 on: May 01, 2013, 02:47:54 am »
Window > Zoom Toggle?  Is that what you are looking for?  Ctrl+Shift+Z in my emulation.
- Ryan
Rodney
  • Hero Points: 48
« Reply #3 on: May 01, 2013, 03:38:52 am »
What Ryan said. Next beta you will be able to configure double-click to zoom btw.
++rodney
dunkers
  • Hero Points: 28
« Reply #4 on: May 01, 2013, 10:56:08 am »
Zoom is exactly the effect on the tab, yes, but then I end up with a single window. My prefered style is for two side-by-side, so zoom is inappropriate, unfortunately.
