Author Topic: "show close buttons on file tabs" option does not seem to do anything.  (Read 2618 times)
davehohl
  • Hero Points: 27
I toggled the setting for "show close buttons on file tabs" back and forth, and nothing seemed to change on the tabs in a tab group -- the "X" to close the tabs is always shown.  If the file tabs window is enabled, this setting does toggle the "X" for those tabs. I would have expected it to do the same for the tab group tabs.
Matthew
  • Hero Points: 44
That setting only affects the "legacy" file tabs tool window for now. We'll migrate that setting to also apply to the new style file tabs in the next beta.
Rodney
  • Hero Points: 53
This has been fixed for the next beta.
++rodney
