Author Topic: Document title when printing?  (Read 1844 times)
jnairb
  • Hero Points: 11
« on: May 07, 2013, 09:28:29 pm »
This isn't really a beta issue since v17 does the same, but on v16 (I think) and earlier, if I printed a file from SlickEdit to a PDF print queue (Adobe Acrobat), the default output name was filename.pdf. With both v17 and v18, the default output name is document1.pdf. If it's something simple, could v18 be changed to switch back to the filename?
I'm running SlickEdit x64 on Windows 7.
Thanks.
