Author Topic: try block expansion?  (Read 2073 times)
Tree
« on: May 09, 2013, 09:24:00 pm »
A feature I used a lot in v17 is the ability to use the arrow keys to surround existing text when adding a try/catch block in java. Where did this feature go?
  • Hero Points: 139
Re: try block expansion?
« Reply #1 on: May 10, 2013, 01:26:49 pm »
Looks like a bug.  We'll take a look at it, thanks for the report.
  • Hero Points: 139
« Reply #2 on: May 10, 2013, 02:11:44 pm »
Fixed for the next beta drop.
