Author Topic: Bug: B4: Core whilst editing.  (Read 1542 times)
lambertia
  • Hero Points: 14
« on: May 21, 2013, 03:46:50 am »
Hi,
I had done a reference search and then used the "previous error" sequence thinking that it would go backwards in the reference search. Of course why would it there are no errors :)
But it went bang and I guess you don't want that :)
I will upload the core file using the label core-vs_exe-1369105098-pid-18951.gz.
Cheers,
Greg.
  • Hero Points: 127
Re: Bug: B4: Core whilst editing.
« Reply #1 on: May 21, 2013, 02:51:18 pm »
Got both of your core files.  Sadly, I can't reproduce either problem on our 10.0.4 system, but I'll see what I can figure out from the dumps.
