Author Topic: Bug: B4: Core whilst editing.  (Read 2197 times)
lambertia
  • Hero Points: 14
« on: May 22, 2013, 03:54:13 am »
Uploaded using key core-vs_exe-1369194630-pid-10257.gz
lambertia
  • Hero Points: 14
Re: Bug: B4: Core whilst editing.
« Reply #1 on: May 22, 2013, 03:54:46 am »
SlickEdit 2013 (v18.0.0.8 32-bit)
Serial number: FE10194_BETA
License type: Beta License
License expiration: 2013-07-25 04:21:00
License file: /opt/slickedit-18.0.0.8/bin/slickedit.lic
Build Date: May 16, 2013
Emulation: Brief
OS: Linux
OS Version: Ubuntu 10.04.4 LTS
Kernel Level: 3.8.0-21-generic
Build Version: #32-Ubuntu SMP Tue May 14 22:16:46 UTC 2013
Processor Architecture: i686
Memory: 41% Load, 1749MB/4172MB Virtual
Shell Info: /opt/slickedit-18.0.0.8/bin/secsh -i
Project Type: Cpp
Language: .cpp (C/C++)
Installation Directory: /opt/slickedit-18.0.0.8/
Configuration Directory: /space/gbarron/work/se/mo-trunk/sc/18.0.0/
« Reply #2 on: May 22, 2013, 05:20:12 pm »
Got it.  Looks like the same root cause as your other crash while editing, but I'm still debugging it.   I have a suspicion it's 32 bit only, but I can't prove it yet.  I'll let you know once I make more progress.
« Reply #3 on: May 22, 2013, 06:48:02 pm »
Could you upload your v18 config directory, same place you uploaded your core files?   If I'm lucky I'll be able to reproduce it with your config;  if I'm not so lucky, having the settings and workspace layout will at least narrow the number of possibilities I'm having to look at.
Thanks again for the reports.
lambertia
  • Hero Points: 14
« Reply #4 on: May 22, 2013, 11:10:29 pm »
On the way!
« Reply #5 on: May 23, 2013, 01:19:00 pm »
Got it, thanks.
