Author Topic: Perforce: Delete file confuses slick  (Read 1249 times)
  • Hero Points: 182
« on: May 22, 2013, 09:07:37 pm »
Setup a project with Perforce support.
Open some file in your perforce client area.
Select "Version Control -> Delete".
The file is removed from the filesystem, but it remains open in slick.
In Slick, select File->Save.
Slick pops an erroor complaining that the file is ReadOnly .... but the file doesn't exist in the filesystem.
Switch away from slick and come back, then slick prompts for what to do with the missing file.
Seems like VCS->Delete should close the buffer too.
  • Hero Points: 134
Re: Perforce: Delete file confuses slick
« Reply #1 on: May 22, 2013, 11:12:45 pm »
It should.  I will take care of this.
  • Hero Points: 134
« Reply #2 on: May 22, 2013, 11:27:03 pm »
This is fixed for the next beta.  I did leave the buffer open if it is modified.
