Author Topic: B4 Bug: Beautify changes doxygen block  (Read 3685 times)
pmason
« on: May 23, 2013, 10:00:29 am »
Beautify changes doxygen block from
 * @author masonp (22/05/2013)
to (Note extra space in // and space at the begging off the blocks there after. Not easily seen in this font)
Re: B4 Bug: Beautify changes doxygen block
« Reply #1 on: May 23, 2013, 02:00:36 pm »
Reproduced.  I think this is an easy fix, I'll take a look later this morning.
Thanks for the report.
« Reply #2 on: May 28, 2013, 01:57:36 pm »
Fixed for the next beta.
pmason
« Reply #3 on: May 31, 2013, 08:13:17 pm »
Confirmed fixed in b5
pmason
« Reply #4 on: June 13, 2013, 09:22:13 am »
Seems to have got lost in b6 and b7
« Reply #5 on: June 13, 2013, 01:30:35 pm »
Reproduced, that's a surprise.  I'll figure out what happened to it.
« Reply #6 on: June 13, 2013, 02:05:30 pm »
Yeah, that was a regression.  Fixed for the next drop.  And I'm adding it to the unit tests so it will yell at me if I break it again.   :-[
pmason
« Reply #7 on: June 14, 2013, 06:47:52 am »
Fixed b8
