Author Topic: Beta 4: still having problems with files being displayed scrolled to right  (Read 10968 times)
davehohl
  • Hero Points: 27
I have a workspace open with 2 tab groups. The file displayed in each tab group has column 0 showing at the left border of the window.
I then open a different workspace, and immediately re-open the original workspace. The file in the right tab group now has column 44 showing at the left border. Somehow SE has automatically scrolled the file over.
This behavior seems to be intermittent, although once it happens I can then repeat it consistently by switching back and forth between projects.
SlickEdit 2013 (v18.0.0.8 32-bit)
Serial number: FE25543_BETA
License type: Beta License
License expiration: 2013-07-24 12:01:00
License file: C:\ProgramData\slickedit\18\slickedit.lic
Build Date: May 16, 2013
Emulation: CUA
OS: Windows 7
Memory: 77% Load, 2557MB/3318MB Physical, 3404MB/6635MB Page File, 256MB/2047MB Virtual
Screen Size: 1920 x 1200
Project Type: Cpp
Language: .h (C/C++)
Installation Directory: C:\Program Files\SlickEditV18.0.0 Beta4\ (non-removable drive,NTFS,220065MB free)
Configuration Directory: U:\MyDocs\My SlickEdit Config\18.0.0\ (remote,NTFS,31559MB free)
Spill File: C:\Users\david.hohl\AppData\Local\Temp\$slk.7 (non-removable drive,NTFS,220065MB free)
dholshou
Re: Beta 4: still having problems with files being displayed scrolled to right
« Reply #1 on: November 12, 2013, 07:53:03 PM »
Any help on this?
I'm having a very similar issue on SlickEdit 2013 (v18.0.1.2 64-bit)
I don't use "tab groups" (not that I know of) but I have many files open.
At random times, when I switch files VSlick is scrolled far to the right.
Moving to v18 has been a very bad upgrade for me.
It fixed a different issue but brought along others (this one and 1 other) that are at least as annoying.
Build Date: August 12, 2013
Emulation: Vim
OS: Windows 7 x64
Fixed: http://community.slickedit.com/index.php/topic,9555.0.html
New problem: http://community.slickedit.com/index.php/topic,9479.msg40956.html#msg40956
