Author Topic: B4: Modified filename on filetab no longer changes color (red)  (Read 1883 times)
davew
  • Hero Points: 6
When modifying a file, the filename on the File Tab has always changed to red to show that it was modified.
This is no longer working in this Beta.
I verified that the setting is to do this in Options > Appearance > Colors > Application colors > Modified file
« Last Edit: May 24, 2013, 01:35:54 pm by davew »
Ryan
  • Hero Points: 77
Re: B4: Modified filename on filetab no longer changes color (red)
« Reply #1 on: May 23, 2013, 08:40:30 pm »
It's at Tools > Options > Editing > Editor Windows > Color modified document tabs.
- Ryan
davew
  • Hero Points: 6
« Reply #2 on: May 24, 2013, 01:34:03 pm »
OK, it was off and I turned it on, but still no change in file name color.
SE seems to do a good job of porting settings from previous versions, but I see this is a new setting (at least at this location), so I guess you decided the default would be OFF.
Edit: Ah, after restarting B4, now it works, so some state is not being changed until restart.
« Last Edit: May 24, 2013, 01:36:17 pm by davew »
