Author Topic: How to merge tab groups with multiple tabs  (Read 2401 times)
  • Hero Points: 123
« on: May 29, 2013, 07:22:15 pm »
Hi:
Sometimes I work with 2 different horizontal tab groups, and each tab group has multiple tabs in it.
After a while, I want to switch back to one tab group.
Is there any way to merge all the tabs together in 1 tab group with just a few clicks?
Right now, it seems I have to go to each tab and do "Move to tab group above".  It is a little tedious.
Rob
Matthew
  • Hero Points: 44
Re: How to merge tab groups with multiple tabs
« Reply #1 on: May 29, 2013, 08:35:11 pm »
Right now there's not an operation for it. There will be. In the meantime, with Beta 5 you can...
1. Invoke context menu "Float All" which will float all the tabs in the group
2. In the newly-floating group invoke context menu "Move All to Main Document Group"
  • Hero Points: 470
« Reply #2 on: May 29, 2013, 08:52:58 pm »
Try "untile" (window>untile)
  • Hero Points: 123
« Reply #3 on: May 29, 2013, 09:12:26 pm »
Window->Untile works!  I used beta5.  Thanks!
