Author Topic: Beta 6: SE maximizes after changing workspaces  (Read 3204 times)
davehohl
  • Hero Points: 27
« on: May 31, 2013, 11:28:34 pm »
If I make the SE window smaller than maximum size (by clicking on the Maximize/Restore Down button)  and then switch to a different project, the window automatically maximizes.
Note: I checked v17 and it exhibits the same behavior, so this is not new.
Windows 7, 32-bit
John H.
  • Systems and kernel programmer
Re: Beta 6: SE maximizes after changing workspaces
« Reply #1 on: June 03, 2013, 06:02:55 pm »
I just reproduced this problem also, on Linux 64-bit, also with Beta 6:
SlickEdit 2013 (v18.0.0.10 64-bit)
Serial number: FE26181_BETA
License type: Beta License
License expiration: 2013-07-15 10:03:00
License file: /opt/slickedit/bin/slickedit.lic
Build Date: May 30, 2013
Emulation: Visual Studio
OS: Linux
OS Version: Debian GNU/Linux 7.0 (wheezy)
Kernel Level: 3.9.4-<user>-<hostname>
Build Version: #1 SMP Fri May 24 14:22:08 PDT 2013
Memory: 63% Load, 18118MB/28732MB Virtual
Shell Info: /bin/bash -i
Screen Size: 2560 x 1600, 1920 x 1200
Project Type: Gnuc
Language: No file open
Installation Directory: /opt/slickedit/
Configuration Directory: /home/<user>/.slickedit/18.0.0/
Spill File: /tmp/$slk.<user>.26555
  • Hero Points: 428
« Reply #2 on: June 03, 2013, 09:53:24 pm »
OS: Linux
Project Type: Gnuc
This could be the window manager. Some Linux window managers will maximize a window if it is close to being maximized. I've had this happen on Ubuntu. My Ubuntu machine has a small monitor. Try making the window much smaller than maximized and see if there is a difference.
davehohl
  • Hero Points: 27
« Reply #3 on: June 03, 2013, 10:43:38 pm »
I tried making the window really small, and it still maximized when I switched projects. This was on Win 7 32-bit.
chrisant
  • Hero Points: 131
« Reply #4 on: June 04, 2013, 03:48:40 am »
I can't repro on SE 17.0.2 on Win8 x64.
What happens if you try with a fresh config?
E.g. "vs.exe -sc c:\temp\FreshConfig"
  • Hero Points: 428
« Reply #5 on: June 04, 2013, 12:22:58 pm »
So far, I can't reproduce this. Try renaming your <workspace>.vpwhist file before opening it. It has the auto-restore information in it for the workspace.
Sandra
  • Hero Points: 36
« Reply #6 on: June 04, 2013, 01:38:55 pm »
I was able to reproduce this one.  I'll see if I can figure out what's going on.
  • Hero Points: 428
« Reply #7 on: June 04, 2013, 02:21:53 pm »
This bug has gray hair and can be reproduced in v16 and before. Here's how you reproduce it:
* Exit SlickEdit when it is maximized (this is key)
* Now every workspace you open will be restored with the main MDI window maximized.
