Author Topic: Tornado 2.2 WSP workspace and project loading broken  (Read 1902 times)
DanW
« on: June 03, 2013, 08:49:25 pm »
In v15.0.1 tornado workspaces and project loading worked.
In 16 and 17 it was broken, although someone there made a patch which fixed the loading almost 100% (except for a new bug where only the first cpp was loaded as .c)
Now in beta 18, when we load a Tornado 2.2 workspace, only the headers show in the projects pane.    no .c or .cpp file are visible.  :(
Attached is a screenshot.
« Last Edit: June 03, 2013, 09:13:16 pm by DanW »
Re: Tornado 2.2 WSP workspace and project loading broken
« Reply #1 on: June 04, 2013, 01:41:07 pm »
Could you zip up your workspace and project files so I could test them?  The sample Tornado workspaces I have tested appear to be loading and displaying correctly.
DanW
« Reply #2 on: June 04, 2013, 03:12:33 pm »
here the main workspace and an example project.
Hope that helps
« Reply #3 on: June 05, 2013, 01:07:36 pm »
Thanks for the report and the sample.  This will be fixed in the next drop.
DanW
« Reply #4 on: June 13, 2013, 04:01:43 pm »
cpp & c loading when import a tornado project seems to be fixed.
Did notice a new bug, I will post a new topic about it.
