Author Topic: B6: Diff "Del File" not always working  (Read 1534 times)
PiezonTM
  • Hero Points: 7
« on: June 04, 2013, 05:25:41 pm »
I have found that if you select more than one file on one side of the diff window and use the "Del File" often only one file is often deleted.  It makes no difference if they are sparsely selected, all in a row, or all in a single directory.
I am using Ubuntu 12.04.
  • Hero Points: 137
Re: B6: Diff "Del File" not always working
« Reply #1 on: June 05, 2013, 02:18:36 pm »
I was able to reproduce this.  I'm looking into it now.  Thanks for the report.
  • Hero Points: 137
« Reply #2 on: June 05, 2013, 03:10:18 pm »
This is fixed for the next beta.
