Author Topic: Scrolling in current context list  (Read 3645 times)
amanison
« on: June 11, 2013, 12:00:56 pm »
The current context list doesn't appear to have a scroll bar. Is this intentional? The scroll wheel works, but in a large header file with lots of structures it still is a bit tedious. A scroll bar would get to the require area of the file quicker.
  • Hero Points: 481
Re: Scrolling in current context list
« Reply #1 on: June 11, 2013, 07:59:51 pm »
Which platform are you seeing this on?  I get a scroll bar on all platforms (tested Windows, Mac, and Solaris), provided there are enough items in the current context to require a scroll bar.
amanison
« Reply #2 on: June 11, 2013, 09:54:55 pm »
This happens on Fedora 17, 64-bit. I will try to get a screenshot and post it.
amanison
« Reply #3 on: June 17, 2013, 10:09:50 pm »
Attached is a screenshot of the current context list. The arrows at top and bottom show that the list extends above and below the entries displayed. There is no scroll bar to facilitate rapid selection of the relevant portion of the list. This is the version information:
SlickEdit 2013 (v18.0.0.12 64-bit)
Serial number: FE13692_BETA
License type: Beta License
License expiration: 2013-08-21 04:29:00
License file: /opt/slickedit/bin/slickedit.lic
Build Date: June 13, 2013
Emulation: Brief
OS: Linux
OS Version: Fedora release 17 (Beefy Miracle)
Kernel Level: 3.8.13-100.fc17.x86_64
Build Version: #1 SMP Mon May 13 13:36:17 UTC 2013
X Server Vendor: Fedora Project
Memory: 93% Load, 1164MB/1242MB Virtual
Shell Info: /opt/slickedit/bin/secsh -i
Screen Size: 1920 x 986
Project Type: Gnuc
Language: .hpp (C/C++)
Installation Directory: /opt/slickedit/
Configuration Directory: /home/amanison/.slickedit/18.0.0/
Spill File: /tmp/$slk.amanison.10142
