Author Topic: B7: SlickEdit crashes on Startup loading Source Files from Visual Studio Project  (Read 16449 times)
Rodney
  • Hero Points: 54
Thanks for uploading your config. I do not have a fix yet, but I have tracked the problem to 'File tab sort order' option under Options>Editing>Editor Windows. The 'Most recently viewed' option is the culprit. Until we have a fix, you can do the following:
1. Delete or rename your config-dir/vrestore.slk autorestore file. This will resert your layout (tool windows, toolbars, etc.).
2. Start the editor (there will be no files open).
3. Change your File tab sort order to be something else.
4. Exit and restart.
++rodney
Rodney
  • Hero Points: 54
This is fixed for the next release. Thanks for all your help tracking this down!
++rodney
