Author Topic: Beta 8: Request, Floating windows  (Read 1828 times)
Jerm_jp
« on: June 14, 2013, 08:00:02 am »
Could a floating window's file tab be hidden if there is only one file visible?
  • Hero Points: 417
Re: Beta 8: Request, Floating windows
« Reply #1 on: June 14, 2013, 08:19:27 am »
Because I set "Files per window" to "Multiple files share window", I only see one document tab for any document tab group. This is non-standard though and if you haven't been using it already I wouldn't think you would like it.
I'm assuming you are talking about the document tabs and not the old File Tabs tool window. The File Tabs tool window always shows a tab for each file.
Jerm_jp
« Reply #2 on: June 14, 2013, 08:28:37 am »
If I perform the ctrl-shift-z (zoom-window) the file tab disappears from the floating window.
This is an acceptable workaround for me.
