Author Topic: B8: Tab order still not working correctly  (Read 2029 times)
davehohl
  • Hero Points: 27
« on: June 14, 2013, 04:33:06 pm »
If I use the command line to edit a new file, the tab for the file shows up in the leftmost position of the tab group, even though my "file tab sort order" is set to alphabetic. If I go to options and change to a different setting, and then back to alphabetic, the tabs get reordered properly and new files I open get put in the proper tab order. However, if I exit and restart SE, it goes back to putting newly opened files in the leftmost position.
Win 7 32-bit
  • Hero Points: 440
Re: B8: Tab order still not working correctly
« Reply #1 on: June 14, 2013, 05:52:36 pm »
This will be fixed in the final release.  Good catch!
