Author Topic: Adding New Search window in 17.0.3 results in blank tab  (Read 2491 times)
skywise
  • Hero Points: 10
« on: June 14, 2013, 07:28:57 pm »
Can't test this on B8 because of:
http://community.slickedit.com/index.php/topic,9286.0.html
But maybe someone else can -
Win7 x64
I've got my search window docked and hidden and have a search<0> and search<1> tab already loaded out.  I did a new file search (ctrl-shift-f) then selected "New" under search options.
I got a search<2> tab and the search prompt on the commandline said it was successful - but it's an empty tab page (colored the same as the tab banner as if the text window isn't there at all not an empty text field)
Re: Adding New Search window in 17.0.3 results in blank tab
« Reply #1 on: June 14, 2013, 08:03:28 pm »
Reproduced.  I will look into it.
