Author Topic: Beta 8 Win64: Perforce "History Diff On" issue  (Read 4058 times)
rozum
  • Hero Points: 5
« on: June 18, 2013, 06:05:41 pm »
Hello All,
I am having an issue with using SlickEdit to observe the file differences within a Perforce repository.  If I:
  • Open a file that is contained in Perforce.
  • Select: Tools->Version Control->History Diff On <my file>
I get the following "dialog" box messages:
  (PerforceDiffIssue1.png)
  (PerforceDiffIssue2.png)
And when I "OK" them, the "History Diff" dialog window appears.
  (PerforceDiffIssue3.png)
Things to Note
  • The file is part of Perforce and I can check it out via SlickEdit
  • After the first message box appears (PerforceDiffIssue1.png), the cursor is a busy cursor.
  • The "History Diff" dialog window seems to know the history of the file.
  • Our perforce repository is used by both Windows and Linux.
Thanks ahead of time for the assistance in understanding and correcting this issue.
  • Hero Points: 153
Re: Beta 8 Win64: Perforce "History Diff On" issue
« Reply #1 on: June 18, 2013, 06:30:10 pm »
Can you turn on SVC logging and run it and send me the log output?  There is something in the format that I [obviously] didn't pick up right.
rozum
  • Hero Points: 5
« Reply #2 on: June 21, 2013, 03:34:40 am »
Done.  The logs has been sent to your private message box.
  • Hero Points: 153
« Reply #3 on: June 21, 2013, 12:19:01 pm »
I haven't received any private messages.
jwagner
« Reply #4 on: June 21, 2013, 04:59:40 pm »
I am able to get this to work with my Perforce setup, however there is no easy way to make the History Diff window full screen.  I am forced to drag the edges/corners of the window to resize it.  Standard double-clicking of the top bar doesn't allow to snap to full screen either.  Also there is no button in the top right corner to make full screen as most windows have.
I am using Windows 7 64bit.
Is there a way to make this possible?
rozum
  • Hero Points: 5
« Reply #5 on: June 21, 2013, 05:02:14 pm »
Hello Dan,
Sorry about that.  I have resent the private message.
Stephen
