Author Topic: bufftabs.e hack for binding tab sort order commands  (Read 3112 times)
MindprisM
  • Hero Points: 8
« on: July 22, 2013, 09:57:39 am »
SlickEdit 2012 (v17.0.3.0 64-bit)
In the tabs popup menu, there are sort order commands: Alphabetical, Last Opened, Last Viewed and Manual.
These do not exist as independent _commands that can be bound to keys.
Add the following to bufftabs.e:
_command void set_file_tab_sort_order_alpha(...) name_info(','VSARG2_CMDLINE|VSARG2_EDITORCTL){
   set_file_tab_sort_order(FILETAB_ALPHABETICAL);
   sticky_message('Tabs ordered alphabetically, A O V M');
_command void set_file_tab_sort_order_opened(...) name_info(','VSARG2_CMDLINE|VSARG2_EDITORCTL){
   set_file_tab_sort_order(FILETAB_MOST_RECENTLY_OPENED);
   sticky_message('Tabs ordered recently opened, A O V M');
_command void set_file_tab_sort_order_viewed(...) name_info(','VSARG2_CMDLINE|VSARG2_EDITORCTL){
  set_file_tab_sort_order(FILETAB_MOST_RECENTLY_VIEWED);
  sticky_message('Tabs ordered recently viewed, A O V M');
_command void set_file_tab_sort_order_manual(...) name_info(','VSARG2_CMDLINE|VSARG2_EDITORCTL){
  set_file_tab_sort_order(FILETAB_MANUAL);
  sticky_message('Tabs ordered manually, A O V M');
And bind to taste.
