Author Topic: error, when using "FIND in files" option  (Read 3855 times)
jrubio
« on: January 22, 2007, 07:44:28 pm »
 ??? Confusing, everytime I try to do "Find in Folders" I get "unrecognized comman ""(0)" Dialog box?  I have 11.0.2 with all hotfixes, but nothing fixes this? I am using Fedora Core 6. Any help would be appreciated.  I have a dual license and on Windows I do not get this error.
Thanks
Jose
Kohei
  • Hero Points: 25
Re: error, when using "FIND in files" option
« Reply #1 on: January 22, 2007, 08:55:31 pm »
Hi Jose,
This is a known problem, especially on newer distros such as FC6 where a recent version of fontconfig library is used.  You can do the following as a temporary workaround:
As root, open the fontconfig configuration file located at /etc/fonts/fonts.conf, and find two cachedir elements near the top of the file.  Either comment them out or delete them, and save the file.
This problem is fixed in the next major release of SlickEdit.
Hope this helps.
Kohei
jrubio
« Reply #2 on: January 22, 2007, 11:21:29 pm »
 ::) Yeah!!! It works now. Thanks.. Hopefully other people can query this..  and find the answer.
