Author Topic: 18.0.1.2 + Hot fix's Git Version control Menu (Windows Only) breaks  (Read 3188 times)
pmason
The following occurs when enabling the version control menu for git (Using cygwin git, which works if using the command line). Exiting the VC dialog box and then trying to go back into the version control menu. Disabling the VC gets the menu back with no problems. Works ok using the Linux version of sc/and git.
 Invalid object handle
svc.ex 4198 _OnUpdate_svc_history(
   1:
  • =30
   1:   [1]=1
   1:   [2]=1
   1:   [4]=0
   2:   0
   3:   svc_history
   p_window_id: 1
   p_object: OI_DESKTOP
   p_name:
menu.ex 6981 _OnUpdate(
   1:
  • =30
   1:   [1]=1
   1:   [2]=1
   1:   [4]=0
   2:   0
   3:   svc_history
   p_window_id: 155
   p_object: OI_IMAGE
   p_name:
  • Hero Points: 153
Re: 18.0.1.2 + Hot fix's Git Version control Menu (Windows Only) breaks
« Reply #1 on: September 10, 2013, 12:22:31 pm »
Did you have any files open?
pmason
« Reply #2 on: September 10, 2013, 01:32:31 pm »
That seems to be the problem.
Opening a file makes it behave.
  • Hero Points: 153
« Reply #3 on: September 10, 2013, 01:42:53 pm »
OK.  This is already fixed for the next version - I'll make a note to put it in a hotfix as well.
pmason
« Reply #4 on: September 10, 2013, 01:52:26 pm »
Not a big problem now I know what to do
Many Thanks for your quick reply
Paul
  • Hero Points: 153
« Reply #5 on: September 10, 2013, 02:00:20 pm »
This will be fixed in the next hotfix.
