Author Topic: Diffzilla Horribly Broken  (Read 2690 times)
gsexton
« on: September 10, 2013, 03:24:14 PM »
Well, the title says it all. I'm doing a Version Control Diff with most up to date version. In the attachments, Snapshot 5 shows the output of the CVS diff command. Snapshot 6 and 7 show SlickEdit's diff output.
This is done with version 18.0.1.2 with all cumulative hotfixes loaded.
This is just really bad.
  • Hero Points: 155
Re: Diffzilla Horribly Broken
« Reply #1 on: September 10, 2013, 03:46:03 PM »
I put in some code to try to leverage CVS's built-in diff command display our results based on that.  I'm going to change it back to the way it used to work.  There will be a hotfix soon.
