Home
Help
Search
Login
Register
SlickEdit Community
Archived Read Only Forums
SlickEdit® Core for Eclipse
Core for Kepler Beta
Core for Kepler : Betas now available
« previous
next »
Print
Pages: [
1
2
3
Go Down
Author
Topic: Core for Kepler : Betas now available (Read 190192 times)
Matthew
SlickEdit Team Member
Senior Community Member
Hero Points: 44
on:
April 25, 2014, 02:55:29 PM »
The binaries for SlickEdit Core 4.3 are now available in Beta for both Windows and Linux, both 32 and 64 bit platforms.
Use the following URL for your software update site:
https://customer.slickedit.com/update/secore/kepler_beta
NB: Earlier betas that we published may have pointed you to the
URL, and that location may still be present in your "Available Software Sites" list. Please make sure you point your update to the kepler_beta URL.
Logged
mckaiju
Community Member
Hero Points: 1
Re: Core for Kepler : Betas now available
Reply #1 on:
April 28, 2014, 09:24:54 PM »
Thank you for the update. I tried to tried to install the new beta and recived the following error:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Unable to read repository at
https://customer.slickedit.com/update/secore/kepler_beta/plugins/com.slickedit.core_4.3.0.jar
Read timed out
This is on 64 bit windows 7 with 64 bit Eclipse Kepler C/C++. Any ideas on how to fix this and is it happening to anyone else?
Thanks
Logged
Matthew
Hero Points: 44
Reply #2 on:
April 29, 2014, 08:05:31 PM »
Were you able to get the package to install after a second attempt? If not, let me know. We do occasionally have times when customers experience timeouts, and we can provide you the contents of the Update Site as a zip file that you can point to locally. I can PM you a link to that if need be.
Logged
mckaiju
Community Member
Hero Points: 1
Reply #3 on:
April 29, 2014, 08:22:32 PM »
Thanks for the reply. I was just able to get it downloaded and installed. Seems like the timeout was due to something weird on my work network, as soon as I switch to personal network it installed fine. Prob just have to stick with zip files from now one while at work. Thanks again
Logged
gchouini
Community Member
Hero Points: 0
Reply #4 on:
May 05, 2014, 10:37:14 AM »
I was able to install the kepler beta, but am unable to run the license manager. I get a "The chosen operation is not currently available" message. I have tried this with the 32 bit (1.8.0) and 64 bit (1.7.0) JRE
Logged
Hero Points: 130
Reply #5 on:
May 05, 2014, 01:22:05 PM »
@gchouini: Which Eclipse and platform are you running on?
Logged
gchouini
Community Member
Hero Points: 0
Reply #6 on:
May 05, 2014, 01:33:14 PM »
kepler sr2 on Linux Centos 6.5 64 bit
Logged
Hero Points: 130
Reply #7 on:
May 05, 2014, 01:51:13 PM »
Thanks. That error message usually means that it was unable to load one of the shared libraries required for SlickEdit Core. So some dependency is likely missing preventing it from loading. Are you running the 32-bit Eclipse?
Logged
gchouini
Community Member
Hero Points: 0
Reply #8 on:
May 05, 2014, 02:00:31 PM »
64 bit eclipse. SlickEdit Core for Kepler was expected to run on 64 or 32 bit eclipse
Logged
Hero Points: 130
Reply #9 on:
May 05, 2014, 02:45:38 PM »
SlickEdit Core has several dependencies that may need to installed. Off the top of my head, I know libgtk-x11-2.0, libgdk-x11-2.0, libgobject-2.0, libfontconfig are big ones, there may be others.
Logged
gchouini
Community Member
Hero Points: 0
Reply #10 on:
May 05, 2014, 03:28:06 PM »
where will I find a list of all package dependancies for the Kepler beta?
Logged
Hero Points: 130
Reply #11 on:
May 05, 2014, 04:11:45 PM »
Try running eclipse using the -vstrace option on the command-line, we can narrow it down to which library is failing to load. Then we can go from there.
Logged
gchouini
Community Member
Hero Points: 0
Reply #12 on:
May 05, 2014, 05:06:43 PM »
The error msg is "com.slickedit.core: Could not load library: /opt/eclipse/plugins/com.slickedit.linux64.libs_4.3.0/slickedit/bin/libvsapi.so: /lib64/libc.so.6: version `GLIBC_2.15' not found (required by /opt/eclipse/plugins/com.slickedit.linux64.libs_4.3.0/slickedit/bin/libvsapi.so)
com.slickedit.core: Stopping Plugin"
Centos 6.5 includes glibc_2.12
Logged
Hero Points: 130
Reply #13 on:
May 05, 2014, 05:35:53 PM »
64-bit Linux build needs at least glibc 2.5 or later. The requirements page on the website and docs need to be updated to include 64-bit Linux requirements.
Logged
gchouini
Community Member
Hero Points: 0
Reply #14 on:
May 07, 2014, 11:46:40 AM »
No support for RHEL or CentOS???
What unique features of glibc-2.15 is SEcore using or is Ubuntu the only distro that SEcore is supporting?
Why pay for yearly maintenance?
Logged
Print
Pages: [
1
2
3
Go Up
« previous
next »
SlickEdit Community
