Author Topic: SE v23.0.1 freezes when trying to load a hot fix  (Read 2591 times)
asandler
  • Hero Points: 27
« on: April 24, 2019, 01:39:02 PM »
This problem started with version v23.0.1. I haven't been able to apply any of the hot fixes. SE window just freezes and becomes blank. It can only be closed with kill -9.
Any advise what to do?
SlickEdit Pro 2018 (v23.0.1.0 64-bit)
Serial number: FWL111202
Licensed number of users: 15
License server: 27100@den03fih.us.oracle.com
Build Date: February 14, 2019
Emulation: Visual C++ 6
OS: Linux
OS Version: Ubuntu 18.04.1 LTS
Kernel Level: 4.15.0-47-generic
Build Version: #50-Ubuntu SMP Wed Mar 13 10:44:52 UTC 2019
Memory: 23% Load, 13428MB/57989MB Virtual
Shell Information: /home/sasandl/slickedit-pro2018/bin/secsh -i
Screen Size: 3840 x 2160, 1080 x 1920
Project Type: (Other)
Language: .c (C/C++)
Encoding: Automatic
Installation Directory: /home/sasandl/slickedit-pro2018/
Configuration Directory: /home/sasandl/.slickedit/23.0.1/
Migrated from: /home/sasandl/.slickedit/23.0.0/
asandler
  • Hero Points: 27
Re: SE v23.0.1 freezes when trying to load a hot fix
« Reply #1 on: April 24, 2019, 03:39:09 PM »
Also, this started with the first hot fix. I've been silently hoping that one of the hot fixes will make it go away, but now 4th is available and the problem is still there.
dougk
« Reply #2 on: April 24, 2019, 05:04:32 PM »
Similar issue here with the Win_x64 edition and the new hotfix_se2301_4_cumulative.zip download.
See attached JPG.
  • Hero Points: 151
« Reply #3 on: April 24, 2019, 05:06:09 PM »
There was a bug with the hotfix version matching, where it could lock up.  If you download the latest installer, and install it, it should be able to apply the hotfixes.  (And once you've done that, the version will show up as 23.0.1.2 in the Help About page).
dougk
« Reply #4 on: April 24, 2019, 07:44:29 PM »
That fixed my issue on Win_64.
asandler
  • Hero Points: 27
« Reply #5 on: April 24, 2019, 07:53:03 PM »
Thanks Patrick. I’ll check and report back.
asandler
  • Hero Points: 27
« Reply #6 on: April 24, 2019, 09:01:05 PM »
Yeah. It worked. Thanks!
