Author Topic: .process buffer stuck in wrong mode  (Read 6020 times)
link
  • Hero Points: 3
« on: August 13, 2019, 03:02:21 AM »
I accidentally changed the Document mode for the build buffer (.process) to something other than Process, and now I can't switch it back.  Process doesn't appear when I go to Document -> Select Mode, and setting it to automatic does nothing.  I can't click on error messages now to switch to the appropriate buffer now that its the wrong mode.  How can I fix this?  SlickEdit Pro 2018 (v23.0.0.10 64-bit Windows)
  • Hero Points: 347
Re: .process buffer stuck in wrong mode
« Reply #1 on: August 13, 2019, 05:50:51 AM »
On the command line you can type
select-mode process
  • Hero Points: 153
« Reply #2 on: August 13, 2019, 11:31:24 AM »
You can also go to Document>Select mode.
link
  • Hero Points: 3
« Reply #3 on: August 13, 2019, 06:51:28 PM »
As I mentioned above, Process does not appear in the list when you got to Document -> Select Mode.  But Graeme's command fixed it.  Thanks so much!
  • Hero Points: 153
« Reply #4 on: August 14, 2019, 01:28:17 PM »
Sorry, I overlooked that.
  • Hero Points: 517
« Reply #5 on: August 14, 2019, 03:21:53 PM »
Omitting "Process" from that menu is intentional.  It isn't exactly the sort of mode you would want to switch any normal file too.  Not a problem except for this rare case where someone, somehow, changes the mode of the build window.  I am going to check in a tweak to disable select-mode from the menu for the process buffer (and a few other SlickEdit specific modes that should not be messed with).
