Hello,
I am running slickedit on Linux.
I open multiple slickedit instances and would like the name of the Workspace or Project show up on the Title bar. I search this forum and found the following links
https://community.slickedit.com/index.php/topic,257.msg67781.html#msg67781https://community.slickedit.com/index.php/topic,17381.msg67662.html#msg67662I downloaded the title_change.e and loaded the macro. Then on the command I typed title_change "name". Did not see any change.
I copied the following lines into a new macro
_command void setappcapflag ( int flag=3 )
_default_option(VSOPTION_APPLICATION_CAPTION_FLAGS,flag);
_config_modify_flags(CFGMODIFY_OPTION);
I loaded the above macro and ran it. It complained that variable VSOPTION_APPLICATION_CAPTION_FLAGS is not availble.
Can somebody please guide me.
