Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Did you know?
F1 Help
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: F1 Help (Read 11857 times)
Lisa
Senior Community Member
Hero Points: 24
User-friendly geek-speak translator extraordinaire
F1 Help
on:
August 16, 2007, 01:22:10 PM »
No need to use the mouse to invoke Help; instead, you can get context-sensitive Help on menu items, dialog boxes, and tool windows by pressing the
F1
key while the item is in focus.
Logged
Ryan
SlickEdit Team Member
Hero Points: 77
Re: F1 Help
Reply #1 on:
August 16, 2007, 01:56:14 PM »
You can also use
F1
help if you are doing SlickC programming, and wish to quickly bring up the help on a function or property. Just hit
F1
while the item is under your cursor.
- Ryan
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
Did you know?
F1 Help
